[Qgis-developer] Building QGIS2.99 cloned from GitHub on Ubuntu 16.10 (yakkety) 64-bit Python
Nyall Dawson
nyall.dawson at gmail.com
Tue Feb 7 20:02:01 PST 2017
On 8 February 2017 at 13:49, <gordon at shieldaig.com> wrote:
> Due to previous error, mentioned in a early post, I installed `geos 3.6.1`
> and because build still failed, I place header file `geos_c.h` in
> src/core/geometry folder and replace `<geos_c.h>` with `"geos_c.h"` in
> `qgsgeometry.h`. This may not have been necessary but I wanted to make it
> clear which header I expected to be used.
> At about 16% output from build shows:
> `/home/gordon/dev/cpp/QGIS/src/core/qgsvectorfilewriter.cpp: In member
> function ‘void QgsVectorFileWriter::init(QString, QString, const QgsFields&,
> QgsWkbTypes::Type, QgsCoordinateReferenceSystem, const QString&,
> QStringList, QStringList, QString*,
> QgsVectorFileWriter::FieldValueConverter*, const QString&,
> QgsVectorFileWriter::ActionOnExistingFile)’:
> /home/gordon/dev/cpp/QGIS/src/core/qgsvectorfilewriter.cpp:327:55: warning:
> suggest braces around empty body in an ‘else’ statement [-Wempty-body]
> QgsDebugMsg( "Opened data source in update mode" );`
Thanks! Fixed in
https://github.com/qgis/QGIS/commit/2f68d1a7c3f4c7e2137dc20458556facf199d79f
> At about 90% output from build shows:
> `Traceback (most recent call last):
> File "../../../../scripts/pyuic-wrapper.py", line 26, in <module>
> import qgis.PyQt.uic.pyuic
> File "/home/gordon/dev/cpp/QGIS/build/output/python/qgis/__init__.py",
> line 28, in <module>
> from qgis.core import QgsFeature, QgsGeometry
> File
> "/home/gordon/dev/cpp/QGIS/build/output/python/qgis/core/__init__.py", line
> 34, in <module>
> from qgis._core import *
> ImportError: /usr/lib/x86_64-linux-gnu/libQt5Network.so.5: symbol
> _Z15qIsEffectiveTLDRK7QString, version Qt_5 not defined in file
> libQt5Core.so.5 with link time reference
> python/plugins/db_manager/CMakeFiles/zzz-db_manager-15-depend.dir/build.make:72:
> recipe for target 'python/plugins/db_manager/ui_DlgAddGeometryColumn.py'
> failed
> make[2]: *** [python/plugins/db_manager/ui_DlgAddGeometryColumn.py] Error 1
> CMakeFiles/Makefile2:4925: recipe for target
> 'python/plugins/db_manager/CMakeFiles/zzz-db_manager-15-depend.dir/all'
> failed
> make[1]: ***
> [python/plugins/db_manager/CMakeFiles/zzz-db_manager-15-depend.dir/all]
> Error 2
> make[1]: *** Waiting for unfinished jobs....`
> Anyone know how to fix this issue? I used Python3.
Not sure on this one - did you clean your build folder after resolving
the dependency issues?
Nyall
> At about 95% `make -j3` terminated before `qgis` executable built.
> Gordon
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
