[Qgis-developer] Building QGIS2.99 cloned from GitHub on Ubuntu 16.10 (yakkety) 64-bit Python
Jürgen E. Fischer
jef at norbit.de
Fri Feb 10 05:20:00 PST 2017
Hi Gordon,
On Thu, 09. Feb 2017 at 11:40:41 -0500, gordon at shieldaig.com wrote:
> Thanks Jürgen. I see your approach. I have done it with other
> packages but am not sure why I cannot get `pyqt5-dev` and
> `pyqt5-dev-tools` 5.6.1 version directly from the `repo` as it did
> exist last year. That would be the simplest solution.
yakkety has pyqt5-dev-tools=5.7+dfsg-2. But it actually depends on
python3-pyqt5=5.7+dfsg-2, which in turn is depends on libqt5core5a (>=
5.6.0~beta) - which is libqt5core5a=5.6.1+dfsg-3ubuntu6~4 in yakkety
(see [0] ff)
So no need to downgrade pyqt5 - it's built against Qt 5.6.1.
> PyQt5 or package `python-pyqt5` can be removed and installed with
> `sudo pip3 install` using the Qt 5.6.1 `.whl` file.
Mixing debs and pip might create a mess. I'd avoid that. And given the above,
there's no need to anyway.
Jürgen
[0] http://packages.ubuntu.com/search?keywords=pyqt5-dev-tools&searchon=names&suite=yakkety§ion=all
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170210/676abc59/attachment.sig>
