[Qgis-developer] running processing tests for processing algorithms on windows
Alessandro Pasotti
apasotti at gmail.com
Mon Feb 13 08:58:36 PST 2017
If you can run docker and/or vagrant on Windows (and I'm pretty sure you
can), you might want to use on of or CI testing machines:
htps://hub.docker.com/r/boundlessgeo/qgis-testing-environment/tags/
master is current QGIS(3) master
master_2 is 2.18
release is 2.14
Readme:
https://github.com/boundlessgeo/qgis-testing-environment-docker
On Mon, Feb 13, 2017 at 5:12 PM, Johan Van de Wauw <
johan.vandewauw at gmail.com> wrote:
> Hi all,
> One of my colleagues would like to write some unit tests for processing.
> We were able to create some testfiles, but we failed to find an easy
> way to run the testsuite on windows. Anyone a hint on the best way to
> proceed?
> Kind Regards,
> Johan
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170213/a22f46ce/attachment-0001.html>
