[Qgis-developer] How to remove PyQt5? - using QGIS2.99, Python 3.5.3, Qt 5.7 or Qt 5.8, and g++ 6.3 on Ubuntu 17.04 (Zesty) 64-bit
gordon at shieldaig.com
Wed Feb 15 18:25:24 PST 2017
Before I ask this question on StackExchange, does anyone know how to
completely remove the effects of using `sudo pip3 install PyQt5` as
using `uninstall`, although it does remove a lot, doesn't seem
completely up to the task?
`pip` is very useful. I've reinstalled everything using `sudo apt-get`
even tried purge options too. I would prefer not to use a virtual
machine, reinstall everything, etc.. I have also removed the build
folder. And even upgraded to Zesty.
I still either got this error
`Segmentation fault (core dumped)
python/plugins/db_manager/CMakeFiles/zzz-db_manager-15-depend.dir/build.make:72:
recipe for target 'python/plugins/db_manager/ui_DlgAddGeometryColumn.py'
failed
or no python support, because it does build, if I used `sudo pip3
install PyQt5` because it is now 5.8 or other errors if I specified
`==5.7`.
This seems like a `very very small` problem and I hope and I am not the
only person trying to keep their system current and running into these
kinds of problems.
Gordon
PS. I can switch everything to Qt 5.8 as I downloaded source build files
for qtwebkit 5.7 and 5.8 and pypt5 5.7 and 5.8 but don't really want to
do that either. It does make the build environment more flexible.
