[Qgis-developer] Field Menu Range settings odd behaviour
roy roy
royroge at outlook.com
Wed Feb 22 08:44:45 PST 2017
working with Field menu range in QGIS 2.18 I notice that the problem
is still there despite the introduction of costraint:
say that i want to set a range for an integer field
called "numfield" with
min value 1
max value 5
step 1
at this point i would expect that QGIS only accepts "1 2 3 4 5" and
throw an error if i insert 6
to enforce this behaviour I set some costraints:
not NULL
"numfield" >= 1 AND "numfield" <=5
while editing infact if i erroneously insert "6" QGIS will not complain
and will happily save the maximun value for range (i.e. 5) i find this odd
and a way to defeat the hole pourpose of my setting.
What is really happening is that QGIS automatically change the value I insert
with the max range value which is clearly an error that leads to data corruption;
if someone can confirm i'll open a Bug report.
Thanks, Roy.
Il 21/11/2016 09:40, Matthias Kuhn ha scritto:
> Hi,
> With QGIS 2.16 constraints have been introduced that are able to check
> entered values and provide feedback as well as prevent the user from
> clicking ok:
> https://www.qgis.org/en/site/forusers/visualchangelog216/index.html#feature-constraints-on-widgets
> All the best
> Matthias
> On 11/21/2016 09:18 AM, roy roy wrote:
>> Hi:)
>> Anybody interest in this issue?
>> Il 17/11/2016 11:36, roy roy ha scritto:
>>> Hi,
>>> working with field menu (QGIS 2.14.8 OSGEO4W64) i noted a behaviour that
>>> i find misleading and
>>> could potentially lead to severe errors in edit session:
>>> say that i want to set a range for an integer field with
>>> min value 1
>>> max value 5
>>> step 1
>>> while editing; infact if i erroneously insert "6" QGIS will not complain
>>> and happily save the
>>> maximun value for range (i.e 5) i find this odd and a way to defeat the
>>> hole pourpose of my
>>> setting.
>>> I think this is a bug, can anyone confirm? If this is the expected
>>> behaviour i think the logic
>>> of this tool is flawed because QGIS should not insert values at his own
>>> will but should instead warn the
>>> user that the value is outside the expected range.
>>> Thanks, Roy.
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
