[Qgis-developer] New feature proposal for the Dissolve tool
Arnaud Morvan
arnaud.morvan at camptocamp.com
Tue Feb 28 01:43:54 PST 2017
Hello Marco,
Note that I'm currently working on a new Algorithm that supersede
dissolve tool.
Here is how it should look like :
Parameters :
* input vector layer
* group_by expression (field name or complex expression, possible
to add conditions on geometry predicates)
* geometry aggregator : collect (multipart) or combine/union
(single part)
* Fields aggregators, for each field :
aggregate function, input field, delimiter (for the concatenate
aggregator)
output filed definition (type, length, precision)
with possibility to add/remove output fields, import the fields
from an existing layer
The UI should looks like the Refactor Fields algorithm.
With this it should be possible to set a neighborhood condition in the
group_by expression.
Cheers
Arnaud
Le 22/02/2017 à 10:32, Marco Grisolia a écrit :
> Hi,
> I recently answered to a question on GIS StackExchange [0]. In this
> question, the asker was looking for a way for dissolving features
> using an adjacency criterion instead of using common attribute field
> (please, follow the link below for a better understanding). This
> feature is already available in the analogous ArcGIS tool when
> the"Create multipart features" option is enabled and I think it could
> be of interest having an additional option like this in the "Dissolve"
> tool main dialog for next releases.
> I never submitted a feature request on the QGIS Project site but,
> since there is already a (very rough) code and a general idea on how
> to approach the issue, I didn't know if this was the case of adding it
> there. Otherwise, let me know if I need to add it on the QGIS Project
> site (if this is the case, I'm sorry for wasting your time).
> Regards,
> Marco
> [0]
> http://gis.stackexchange.com/questions/228267/merging-adjacent-lines-in-qgis
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170228/13035798/attachment.html>
