[Qgis-developer] Dropping the "render" checkbox
Denis Rouzaud
denis.rouzaud at gmail.com
Tue Feb 28 07:34:01 PST 2017
Le mar. 28 févr. 2017 à 09:43, Martin Dobias <wonder.sk at gmail.com> a écrit :
> On Tue, Feb 28, 2017 at 4:22 PM, Matthias Kuhn <matthias at opengis.ch>
> wrote:
> > On 02/28/2017 08:47 AM, Denis Rouzaud wrote:
> >> Hi,
> >> I'm a big -1 on this.
> >> We often use this for digitizing operations such as manual label
> placement.
> >> If you have a projects which takes quite some time to render, it is very
> >> powerful to
> >> 1. place the canvas at the proper extent
> >> 2. disable rendering
> >> 3. move all the labels needed
> >> 4. re-enable rendering for controlling
> > Isn't this an issue triggered by clearing the canvas before the next
> > rendering process has been finished?
> > If the content (per layer) would only be replaced on the screen, once
> > the subsequent rendering process has finished, such tasks would also be
> > possible without using this checkbox.
> Yeah that's one of the things I wanted to improve within MTR, but
> didn't get to it yet - it would definitely make the render flag less
> interesting. And the same thing could be done also for labeling - only
> switch to the newly computed labeling when it is finished.
Indeed "my" use case might be solved if a better rendering process is in
place. I wouldn't mind (for my personal use case) dropping the render
option whenever it is ready. In the mean time I'm available to provide more
details if someone is willing to do these improvements :)
> As Nyall said in the first mail, if you need to use the render flag,
> then there is some problem with rendering - so knowing cases when
> people still use it is very useful as we can make QGIS behave nicely
> without the need for render checkbox! So please keep posting your use
> cases :-)
> Cheers
> Martin
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170228/bac72006/attachment-0001.html>
