[Qgis-developer] CI testing: the straight truth
Tom Chadwin tom.chadwin at nnpa.org.uk
Tue Jan 3 23:33:07 PST 2017
Matthias Kuhn-2 wrote
>  - Move dependencies into separate packages. We have some deps like
>    qspatialite that are built as part of QGIS which I think could be
>    installed as dependencies from a .deb. This will require quite a bit
>    of work: moving travis out of the container based infrastructure to
>    the sudo-enabled infrastructure, setting up a repo (e.g. ppa) with
>    all sort of dependencies including qt 5 etc. This would be an option
>    again since travis enabled caching also on sudo systems recently.
>    This will be a quite large task to do.
There's also the risk that the gains would be eroded by the fact that I
believe sudo-enabled builds are slower than container-based ones.
Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
View this message in context: http://osgeo-org.1560.x6.nabble.com/Travis-The-job-exceeded-the-maximum-time-limit-for-jobs-and-has-been-terminated-tp5301763p5301900.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
