[Qgis-developer] Channel network and drainage basins/ DLL file “gdal_MrSID.dll
Lene Fischer lfi at ign.ku.dk
Thu Jan 5 11:38:59 PST 2017
Algorithm Channel network and drainage basins starting...
io_gdal 0 -TRANSFORM -INTERPOL 0 -GRIDS "C:\Users\nkx236\AppData\Local\Temp\processing9c62242c21ca4504a2eb350d242142cc\483ce22722a4416eb2237bbcce8bba48\FilledDEM.sgrd" -FILES "C:/Users/nkx236/Documents/QGIS_Olea/watershed/FilledDEM2.tif"
ta_channels "Channel Network and Drainage Basins" -DEM "C:\Users\nkx236\AppData\Local\Temp\processing9c62242c21ca4504a2eb350d242142cc\483ce22722a4416eb2237bbcce8bba48\FilledDEM.sgrd" -THRESHOLD 5 -DIRECTION "C:\Users\nkx236\AppData\Local\Temp\processing9c62242c21ca4504a2eb350d242142cc\cc40facb1fcc450cb561ba0f7dd986f4\DIRECTION.sdat" -CONNECTION "C:\Users\nkx236\AppData\Local\Temp\processing9c62242c21ca4504a2eb350d242142cc\79c7f097ffc94ff496877f8bd5a031d3\CONNECTION.sdat" -ORDER "C:\Users\nkx236\AppData\Local\Temp\processing9c62242c21ca4504a2eb350d242142cc\1eed588961424d2db7f4d835a7c9f72c\ORDER.sdat" -BASIN "C:\Users\nkx236\AppData\Local\Temp\processing9c62242c21ca4504a2eb350d242142cc\ca1bbe1febf2411da8cda102d3fb6352\BASIN.sdat" -SEGMENTS "C:/Users/nkx236/Documents/QGIS_Olea/watershed/channels5.shp" -BASINS "C:/Users/nkx236/Documents/QGIS_Olea/watershed/drainage5.shp" -NODES "C:\Users\nkx236\AppData\Local\Temp\processing9c62242c21ca4504a2eb350d242142cc\a22b05dd659a499ca34eaa518ad9bf86\NODES.shp"
C:\PROGRA~1\QGIS2~1.16\bin>set SAGA=C:/PROGRA~1/QGIS2~1.16/apps\saga
C:\PROGRA~1\QGIS2~1.16\bin>set SAGA_MLB=C:/PROGRA~1/QGIS2~1.16/apps\saga\modules
C:\PROGRA~1\QGIS2~1.16\bin>PATH=C:\PROGRA~1\QGIS2~1.16\apps\Python27\lib\site-packages\Shapely-1.2.18-py2.7-win-amd64.egg\shapely\DLLs;C:\PROGRA~1\QGIS2~1.16\apps\Python27\DLLs;C:\PROGRA~1\QGIS2~1.16\apps\Python27\lib\site-packages\numpy\core;C:\PROGRA~1\QGIS2~1.16\apps\qgis\bin;C:\PROGRA~1\QGIS2~1.16\apps\grass\grass-7.0.4\lib;C:\PROGRA~1\QGIS2~1.16\apps\grass\grass-7.0.4\bin;C:\PROGRA~1\QGIS2~1.16\apps\Python27\Scripts;C:\PROGRA~1\QGIS2~1.16\bin;C:\Windows\system32;C:\Windows;C:\Windows\WBem;C:/PROGRA~1/QGIS2~1.16/apps\saga;C:/PROGRA~1/QGIS2~1.16/apps\saga\modules
C:\PROGRA~1\QGIS2~1.16\bin>saga_cmd io_gdal 0 -TRANSFORM -INTERPOL 0 -GRIDS "C:\Users\nkx236\AppData\Local\Temp\processing9c62242c21ca4504a2eb350d242142cc\483ce22722a4416eb2237bbcce8bba48\FilledDEM.sgrd" -FILES "C:/Users/nkx236/Documents/QGIS_Olea/watershed/FilledDEM2.tif"
ERROR 1: Can't load requested DLL: C:\PROGRA~1\QGIS2~1.16\apps\saga\dll\gdal_MrSID.dll
127: The specified procedure could not be found.
_____________________________________________
library path: C:\PROGRA~1\QGIS2~1.16\apps\saga\modules\io_gdal.dll
library name: Import/Export - GDAL/OGR
tool name : GDAL: Import Raster
author : O.Conrad (c) 2007 (A.Ringeler)
Parameters
Grids: No objects
Files: "C:/Users/nkx236/Documents/QGIS_Olea/watershed/FilledDEM2.tif"
Transformation: yes
Interpolation: Nearest Neighbor
loading: C:/Users/nkx236/Documents/QGIS_Olea/watershed/FilledDEM2.tif
Driver: GTiff
Bands: 1
Rows: 15578
Columns: 7994
Transformation:
x' = 881887.358794 + x * 0.399987 + y * 0.000000
y' = 6123496.077786 + x * 0.000000 + y * -0.399987
loading band [1/1]
One of my phd students are working with a SAGA "Channel network and drainage basins”
He wrote this to me - and I have tried to solve the problem by re-install QGIS - but nothing seems to work. At my computer it´s OK
Can someone try to “translate” the problem:
I cannot execute the “Channel network and drainage basins” plug in. A problem in Saga with the DLL file “gdal_MrSID.dll” seems to be the cause. Attached is a screendrop of the dialogue box and a script from the log. My ‘filled DEM’ seems fine.
I am using Qgis 2.18.2, but have also tried an earlier version 2.16 something, with the same result. I use it on a Dell Latitude E6530 with 4 GB RAM and an i5 2.60 GHz processor operated with a 64-bit Windows 7 Enterprise system.
Sincerely,
Jonas
C:\PROGRA~1\QGIS2~1.16\bin>saga_cmd ta_channels "Channel Network and Drainage Basins" -DEM "C:\Users\nkx236\AppData\Local\Temp\processing9c62242c21ca4504a2eb350d242142cc\483ce22722a4416eb2237bbcce8bba48\FilledDEM.sgrd" -THRESHOLD 5 -DIRECTION "C:\Users\nkx236\AppData\Local\Temp\processing9c62242c21ca4504a2eb350d242142cc\cc40facb1fcc450cb561ba0f7dd986f4\DIRECTION.sdat" -CONNECTION "C:\Users\nkx236\AppData\Local\Temp\processing9c62242c21ca4504a2eb350d242142cc\79c7f097ffc94ff496877f8bd5a031d3\CONNECTION.sdat" -ORDER "C:\Users\nkx236\AppData\Local\Temp\processing9c62242c21ca4504a2eb350d242142cc\1eed588961424d2db7f4d835a7c9f72c\ORDER.sdat" -BASIN "C:\Users\nkx236\AppData\Local\Temp\processing9c62242c21ca4504a2eb350d242142cc\ca1bbe1febf2411da8cda102d3fb6352\BASIN.sdat" -SEGMENTS "C:/Users/nkx236/Documents/QGIS_Olea/watershed/channels5.shp" -BASINS "C:/Users/nkx236/Documents/QGIS_Olea/watershed/drainage5.shp" -NODES "C:\Users\nkx236\AppData\Local\Temp\processing9c62242c21ca4504a2eb350d242142cc\a22b05dd659a499ca34eaa518ad9bf86\NODES.shp"
C:\PROGRA~1\QGIS2~1.16\bin>exit
Converting outputs
Loading resulting layers
The following layers were not correctly generated.
•                         Channels
•                         Drainage Basins
You can check the log messages to find more information about the execution of the algorithm
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170105/a9351ff1/attachment-0001.html>
