[Qgis-developer] Merge QGIS Resource Sharing Plugin into core
Alexander Bruy alexander.bruy at gmail.com
Fri Jan 6 08:57:22 PST 2017
IMHO if it will be merged into core, it should replace style manager,
Processing sharing code and Plugin Manager.
2017-01-06 18:33 GMT+02:00 Paolo Cavallini <cavallini at faunalia.it>:
> Il 06/01/2017 17:28, Alessandro Pasotti ha scritto:
>> On Fri, Jan 6, 2017 at 5:20 PM, Matthias Kuhn <matthias at opengis.ch
>> <mailto:matthias at opengis.ch>> wrote:
>>     Hi,
>>     This mainly means it is preinstalled (and enabled) out of the box
>>     and there will updates will happen via the usual QGIS release schedule?
>>     Or is there anything else to it?
>> That should be all.
> +1
> we should also consider in the process if it is worth the while to port
> to this also other resource sharing areas, namely Processing models etc.
> Thanks Alessandro.
> Paolo Cavallini - www.faunalia.eu
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
> https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexander Bruy
