[Qgis-developer] Symbolizing a discrete or a boolean raster
Stéphane Henriod
stephanebek at gmail.com
Tue Jan 10 02:23:19 PST 2017
Hi
let me move here a request that has been shortly discussed on the
user-mailing list:
http://lists.osgeo.org/pipermail/qgis-user/2017-January/038793.html
http://lists.osgeo.org/pipermail/qgis-user/2017-January/038795.html
http://lists.osgeo.org/pipermail/qgis-user/2017-January/038801.html
and for which a ticket is open:
http://hub.qgis.org/issues/14845
I was said that some work has been done in this direction for 3.0 but I
don't know if it completely covers the feature request
When styling a discrete or boolean raster, there seems to be no direct
method, only a few workarounds. The feature I dream of would do the
following:
- A new render type "Discrete raster"
- One button allows to fetch all unique values form the raster (with a
warning message if there are more than XXX unique values)
- A color ramp is applied by default
- I can multi-select values and apply them the same style and / or the
same label
- I can remove values. The pixels with those values will simply not be
displayed
- I can save my color map and load an existing color map
So pretty much like the ArcGIS implementation:
http://resources.arcgis.com/en/help/main/10.1/index.html#/representing_unique_categories_such_as_land_use/009t00000074000000/
The current limitations I see (in 2.14):
- The discrete values must be entered manually, which is a pain for a
raster with many unique values (or if I don't know in advance what all
values are)
- If I click on *Classify*, QGIS will choose X values (based on the
number of classes and the classification method (continuous or equal
interval)), which no longer match the "exact" values of my raster. It
doesn't really make sense to classify a discrete rendering
- Although it is currently possible to style discrete rasters, the
procedure is not really intuitive for beginners
Is this a feature that is envisioned for 3.0? Is there anything I can do to
support it? (except coding it myself, since I don't have the skills for
that...)
Thanks a lot in advance
Cheers
Stéphane
"Le mot progrès n'aura aucun sens tant qu'il y aura des enfants malheureux"
-- Albert Einstein
"Si les contacts avec les étrangers lui étaient permis, [le citoyen
ordinaire] découvrirait que ce sont des créatures semblables à lui-même et
que la plus grande partie de ce qu'on lui a raconté d'eux est fausse. Le
monde fermé, scellé, dans lequel il vit, serait brisé, et la crainte, la
haine, la certitude de son bon droit, desquelles dépend sa morale,
pourraient disparaître" -- George Orwell ("1984")
“When you travel, remember that a foreign country is not designed to make
you comfortable. It is designed to make its own people comfortable." --
Clifton Fadiman
Photos de voyages, photos de montagne: http://www.henriod.info
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170110/f6f4ca66/attachment-0001.html>
