[Qgis-developer] EPSG v9.0 upgrade
    Stéphane Henriod
    stephanebek at gmail.com
    Tue Jan 10 19:56:46 PST 2017
Hi all
is it known already when this will be incorporated into QGIS? In 3.0 or
earlier?
Thanks a lot in advance
Cheers
Stéphane
Le mardi 10 janvier 2017, Even Rouault <even.rouault at spatialys.com> a
écrit :
> Hi,
> I've updated to the EPSG v9.0 database.
> The relevant tickets are:
> * libgeotiff: https://trac.osgeo.org/geotiff/ticket/83
> * GDAL: https://trac.osgeo.org/gdal/ticket/6772
> * proj.4: proj.4: https://github.com/OSGeo/proj.4/issues/477
> * postgis: https://trac.osgeo.org/postgis/ticket/3684 (patch submitted)
> Combined with that update, I've also applied datum shift overrides for
> EPSG:4149 (CH1903), EPSG:3844 (Pulkovo 1942(58) / Stereo70 Romania),
> EPSG:31251,31252,31253 (MGI (Ferro) / Austria), EPSG:2397/2398/2399
> (Pulkovo 1942(83) / 3-degree Gauss-Kruger zone 3,4,5), EPSG:2065 (S-JTSK
> (Ferro) / Krovak).
> Those were awaiting in various GDAL/libgeotif/proj tickets (*), and were
> not doable until now for most of them, since there was no possibility of
> defining datum shift overrides specific to projected coordinate systems,
> before the changes done in https://trac.osgeo.org/geotiff/changeset/2747
> and
> https://trac.osgeo.org/gdal/changeset/37080
> Even
> (*) From libgeotiff ChangeLog:
> 2017-01-10 Even Rouault <even dot rouault at spatialys dot com>
> * csv/datum_shift_pref.csv: add overrides for PCS 2065
> (S-JTSK (Ferro) / Krovak)
> Fixes https://trac.osgeo.org/gdal/ticket/4762 and
> https://github.com/OSGeo/proj.4/issues/185
> * csv/datum_shift_pref.csv: add overrides for PCS 2397/2398/2399
> Fixes https://github.com/OSGeo/proj.4/issues/235
> * csv/datum_shift_pref.csv: add overrides for PCS 31251,31252,31253
> Fixes https://github.com/OSGeo/proj.4/issues/254
> * csv/build_pcs.py, csv/datum_shift_pref.csv: add mechanism to define
> TOWGS84 parameters per PCS (instead of only relying on the TOWGS84
> parameters of the underlying GCS).
> Add override for EPSG:3844 ("Pulkovo 1942(58) / Stereo70" Romania)
> Fixes https://trac.osgeo.org/geotiff/ticket/52
> * csv/datum_shift_pref.csv: add override for CH1903 (EPSG:4149)
> Fixes https://trac.osgeo.org/geotiff/ticket/73
> Spatialys - Geospatial professional services
> http://www.spatialys.com
"Le mot progrès n'aura aucun sens tant qu'il y aura des enfants malheureux"
-- Albert Einstein
"Si les contacts avec les étrangers lui étaient permis, [le citoyen
ordinaire] découvrirait que ce sont des créatures semblables à lui-même et
que la plus grande partie de ce qu'on lui a raconté d'eux est fausse. Le
monde fermé, scellé, dans lequel il vit, serait brisé, et la crainte, la
haine, la certitude de son bon droit, desquelles dépend sa morale,
pourraient disparaître" -- George Orwell ("1984")
“When you travel, remember that a foreign country is not designed to make
you comfortable. It is designed to make its own people comfortable." --
Clifton Fadiman
Photos de voyages, photos de montagne: http://www.henriod.info
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170111/93978932/attachment.html>
