[Qgis-developer] No GRASS7 In Processing in QGIS master
matteo matteo.ghetta at gmail.com
Thu Jan 12 01:14:33 PST 2017
Hi devs,
when I try to run a GRASS algorithm with Processing the following
message appears:
super-class __init__() of type MessageBarProgress was never called See
log for more details
and then the default message that GRASS is not found on the system:
This algorithm cannot be run :-(
It seems that GRASS GIS 7 is not correctly installed and configured in
your system. Please install it before running GRASS GIS 7 algorithms.
GRASS is correctly detected when running cmake:
-- Found GRASS 7: /usr/lib/grass72 (7.2.0, off_t size = 8)
and I can normally use it as standalone.
Are there some issues with my installation or is that a global issue?
Thanks!
Matteo
