[Qgis-developer] QGIS 3 OSGeo Update?
G. Allegri giohappy at gmail.com
Fri Jan 13 09:48:41 PST 2017
ok thanks Matthias. I was worried with Qt5, PyQt5 and so for. I will try
(fingers corssed!).
@Paolo: I run from build dir too, but I was asking about dev libraries not
QGIS build.
2017-01-13 18:27 GMT+01:00 Matthias Kuhn <matthias at opengis.ch>:
> Hi Giovanni,
> I use the same (system provided) dev libraries for both. The only thing
> that could potentially get you into trouble is the recent requirement for
> GDAL >= 2 but QGIS 2.14 is also compatible with newer GDAL versions.
> Matthias
> On 13/01/17 18:17, G. Allegri wrote:
> Matthias, what about dev libraries? Do you keep them in separate folders?
> I have 2.14.10 LTR for my production tests but I would like to build QSIG
> 3. I'm worried that downloading the required dependencies for QGIS 3 will
> cause conflicts, am I wrong?
> giovanni
> 2017-01-13 17:48 GMT+01:00 Matthias Kuhn <matthias at opengis.ch>:
>> I do it happily on a Linux machine as well, either running directly from
>> the build directory or on a custom CMAKE_INSTALL_PREFIX.
>> Matthias
>> On 13/01/17 17:38, G. Allegri wrote:
>> I suppose on Windows it's possible, but on Linux distributions there will
>> be libraries conflicts.
>> giovanni
>> 2017-01-13 17:21 GMT+01:00 Paolo Cavallini <cavallini at faunalia.it>:
>>> Il 13/01/2017 17:19, Luca Mandolesi ha scritto:
>>> > It will possible take togheter QGIS 3 and the old release to make test
>>> > on the same machine or it's better install QGis 3 on a new clean
>>> machine?
>>> it is well possible, I think most of devs are doing it
>>> Paolo Cavallini - www.faunalia.eu
>>> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
>>> https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Qgis-developer mailing listQgis-developer at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170113/3d886577/attachment-0001.html>
