[Qgis-developer] Proposal - Change mIconProjectionEnable/Disable Icons
Nathan Woodrow
madmanwoo at gmail.com
Sun Jan 15 16:05:19 PST 2017
+1 for me. Icons should have the same meaning over all the application.
On Mon, Jan 16, 2017 at 9:56 AM, Alexandre Neto <senhor.neto at gmail.com>
wrote:
> Proposal: for consistency, change the current mIconProjectionEnable and
> mIconProjectionDisable Icons. These are the Icons next to the EPSG code
> Rationale: While converting those icons from PNG to SVG, I could not
> understand what they were, or try to represent. Besides, these buttons open
> the CRS tab in project properties, which uses another Icon (CRS.svg). So,
> for consistency and user's recognition, it would be better to use always
> the same icon when we are referring to select a CRS.
> My idea is to use the CRS.svg icon as a base to create a version for
> enable/disable icons that look good at 16x16 pixels.
> http://imgur.com/O7hKsmK
> I would also replace the Icon in the capture coordinates plugin, which is
> the same.
> Any objections to this?
> Alexandre Neto
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170116/7be82904/attachment-0001.html>
