[Qgis-developer] [Processing] how to handle selections
Bernhard Ströbl
bernhard.stroebl at jena.de
Thu Jan 19 01:52:47 PST 2017
of course, I see. I was under the impression that apart from honoring
the option by using the method you would not run into problems if the
api changes.
Bernhard
Am 19.01.2017 um 10:47 schrieb Victor Olaya:
> hmm, not a bad idea, but it is actually very easy to do that using
> standard QGIS methods (you can see how simple the fix i made is). The
> advantage of vector.features is that it honors the option setting,
> without the developer having to take care of that.
> Cheers
> 2017-01-19 10:43 GMT+01:00 Bernhard Ströbl <bernhard.stroebl at jena.de>:
>> Hi Victor,
>> what do you think about enhancing processing's vector.features with an
>> additional optional flag that returns the selection no matter if the option
>> is set or not?
>> Bernhard
>> Am 19.01.2017 um 10:35 schrieb Victor Olaya:
>>> Good catch
>>> I fixed it and now it uses the selected features, regardless of the
>>> config parameter. The change is in 2.18 and master branches
>>> Thanks!
>>> 2017-01-18 10:44 GMT+01:00 Bernhard Ströbl <bernhard.stroebl at jena.de>:
>>>> Hi all,
>>>> processing sports the "Save selected features" algorithm. However if in
>>>> processing's options you untick "Use only selected features" the
>>>> algorithm
>>>> outputs _all_ features of the input layer. Although I know that
>>>> processing
>>>> works only on selections when the option is ticked IMHO the current
>>>> behaviour is not intuitive: if an algorithm in its name (and help) claims
>>>> to
>>>> do something with the selected features it should do that _all the time_.
>>>> Opinions?
>>>> Background: I opened a PR [1] yesterday for an algorithm that works on
>>>> selected features all the time (won't make sense otherwise) and would
>>>> like
>>>> processing to be consistent in that respect.
>>>> regards
>>>> Bernhard
>>>> [1] https://github.com/qgis/QGIS/pull/4011
>>>> __________ Information from ESET Mail Security, version of virus
>>>> signature
>>>> database 14787 (20170118) __________
>>>> The message was checked by ESET Mail Security.
>>>> http://www.eset.com
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> __________ Information from ESET Mail Security, version of virus signature
>>> database 14793 (20170119) __________
>>> http://www.eset.com
>> http://www.eset.com
> __________ Information from ESET Mail Security, version of virus signature database 14793 (20170119) __________
> http://www.eset.com
http://www.eset.com
