[Qgis-developer] Building a pdf version of QGIS documentation
Werner Macho
werner.macho at gmail.com
Wed Jan 25 08:45:42 PST 2017
Hi!
Seems like you have errors in building so the pdf gets not created.
There should be a logfile somewhere where you can look for the error
(I guess probably a missing package or misformated rst).
seems like texi2dvi has some problems ..
Maybe you can "dryrun" the texi2dvi command line and look for the error ..
regards
Werner
On Wed, Jan 25, 2017 at 5:17 PM, DelazJ <delazj at gmail.com> wrote:
> Hi,
> I'm trying to build a pdf version of QGIS Testing doc, following the readme
> at https://github.com/qgis/QGIS-Documentation. I'm on Ubuntu Xenial.
> The "make LANG=en pdf" command ends with :
> build succeeded, 3 warnings.
> # Compile the pdf docs for that locale
> # we use texi2pdf since latexpdf target is not available via
> # sphinx-build which we need to use since we need to pass language flag
> mkdir -p output/pdf/en
> # need to build 3x to have proper toc and index
> # currently texi2pdf has bad exit status. Please ignore errors!!
> # prepending the texi2pdf command with - keeps make going instead of
> quitting
> # japanese pdf has problems, when build with texi2pdf
> # as alternative we can use platex
> # for russian pdf you need package 'texlive-lang-cyrillic' installed
> # for japanese pdf you need: 'cmap-adobe-japan1 cmap-adobe-japan2
> latex-cjk-all nkf okumura-clsfiles ptex-base ptex-bin texlive-fonts-extra'
> /usr/bin/texi2dvi: pdflatex exited with bad status, quitting.
> Makefile:97 : la recette pour la cible « pdf » a échouée
> make: [pdf] Erreur 1 (ignorée)
> mv output/latex/en/QGISUserGuide.pdf
> output/pdf/en/QGIS-testing-UserGuide.pdf
> mv: cannot stat 'output/latex/en/QGISUserGuide.pdf': No such file or
> directory
> make: *** [pdf] Erreur 1
> I manually added a fake QGISUserGuide.pdf file in output/latex/en/ but it
> still failed with the same message.
> What am I missing? Any help will be welcome.
> Thanks,
> Harrissou
> Qgis-developer mailing list
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
