[Qgis-developer] Processing ctest for QGIS timeout
matteo
matteo.ghetta at gmail.com
Mon Jan 30 03:18:35 PST 2017
I compiled a fresh QGIS master on a virtual machine with ubuntu xenial,
so the machine is super clean (nothing else than the QGIS building
requirements installed)
I still cannot run local ctest for ProcessingQGIS, the terminal just
remains at this line:
4: -- Running /usr/bin/python3
/home/matteo/lavori/QGIS/QGIS/python/plugins/processing/tests/QgisAlgorithmsTest.py
4: Running from build directory!
4: - source directory: /home/matteo/lavori/QGIS/QGIS
4: - output directory of the build:
/home/matteo/lavori/QGIS/build-qgis3/output
4: !!! prefix path was requested, but it is not valid - we do not run
from installed path !!!
as Matthias suggested I also ran the test with gdb [0] to see where the
code gets stuck and it seems that there is a segmentation fault. Here
the pastebin [1] of the complete output.
gdb ends:
Thread 1 "python3" received signal SIGSEGV, Segmentation fault.
0x00007ffff04df00a in
QExplicitlySharedDataPointer<QgsCoordinateReferenceSystemPrivate>::QExplicitlySharedDataPointer(QExplicitlySharedDataPointer<QgsCoordinateReferenceSystemPrivate>
const&) () from
/home/matteo/lavori/QGIS/build-qgis3/output/lib/libqgis_core.so.2.99.0
Thanks to all that can help on this!
Cheers
Matteo
[0]
https://github.com/qgis/QGIS/blob/85146ca4be9242e0f6c81e0479eb1cc375a04b49/tests/README.md#run-python-tests-in-gdb
[1] http://pastebin.com/FP9NKeAQ
