[QGIS-Developer] Error with "PostGIS execute SQL'
matteo matteo.ghetta at gmail.com
Mon Jul 3 02:33:45 PDT 2017
the function "PostGIS execute SQL' of Processing seems not returning any
results in QGIS, even with simple query like:
SELECT * FROM test
or
SELECT * FROM test where id > 10
the same strings on the same db and layer are working fine in DB Manager
and with the "Add Layer" button.
Should I open a ticket?
Thanks
Matteo
More information about the QGIS-Developer mailing list
