[QGIS-Developer] QGIS 3 > Processing: some test
matteo
matteo.ghetta at gmail.com
Tue Jul 4 00:57:43 PDT 2017
Hi Nyall,
>>>> * barplot does not return a result (result viewer is empty)
>>> Looks like this happens when you don't pick a destination file. Can
>>> you re-test and explicitly choose an output file.
>> tried, still empty wpanel
I notice that with all the algorithm that return html outputs, the
result viewer is empty and one can get the result just by saving the
output as local html in a folder.
Can I help to solve this problem?
Thanks!
Matteo
