[QGIS-Developer] QGIS/OGR: FeatureIds reassigned on write to data provider?
Sandro Mani manisandro at gmail.com
Thu Jul 6 02:00:48 PDT 2017
On 06.07.2017 10:57, Even Rouault wrote:
> On jeudi 6 juillet 2017 10:45:21 CEST Sandro Mani wrote:
> > On 05.07.2017 14:56, Sandro Mani wrote:
> > >> That could potentially be done using the current OGR API. Basically
> > >> in pseudo code, to execute before executing REPACK
> > >> OGR_L_ResetReading(layer)
> > >> char** ignored_fields = CSLAddString(NULL, "OGR_GEOMETRY" );
> > >> OGR_L_SetIgnoredFields( layer, ignored_fields); // for performance.
> > >> CSLDestroy(ignored_fields);
> > >> OGR_L_SetAttributeFilter( layer, NULL )
> > >> OGR_L_SetSpatialFilter( layer, NULL )
> > >> std::map<GIntBig, GIntBig> mapOldIdToNewId;
> > >> GIntBig newId = 0;
> > >> while( feature = OGR_L_GetNextFeature(layer) )
> > >> mapOldIdToNewId[OGR_F_GetFID(feature)] = newId;
> > >> newId ++;
> > >> OGR_F_destroy(feature);
> > >> OGR_L_SetIgnoredFields( layer, NULL );
> > > Ok cool, that sounds like a plan - I'll give it a shot.
> > Hmm so while on the provider side it works well, for the geometry
> > checker it is turning out to be pretty hard to deal with the changing
> > feature ids (just to cite one example: error fixed by merging geometry
> > of feature 10 with that of 11, results in {deleted: 10, updated: 11},
> > but after the feature id adjustment this would read {deleted: 10,
> > updated: 10}, meaning one would need to keep track that deleted: 10
> > refers to the old featureid). Not saying that it isn't doable, but the
> > complexitiy of properly handling the feature id changes is non-trivial.
> > So, other suggestion: any objections if I add a method to
> > QgsVectorDataProvider to temporarily freeze repacking? I could also add
> > a notification informing the user that the shapefile should not be used
> > in other applications while repacking is frozen.
> My feeling is that QgsOgrDataProvider is already complicated enough
> with its existing tricks. I'm not sure this temporary freeze repacking
> is a right move (how would you decide when you do it ? and I'm pretty
> sure users will not get it, or will have issues if they start an
> algorithm with an external tool that requires packed shapefiles)
It would be something I would call explicitly while the geometry checker
is active, I think it is safe to assume that users don't expect that
they can operate on the shapefile while the geometry checker is
processing it.  It would not add much complexity to the provider, just a
flag that repacking is frozen, and a setter to set that flag. When the
flag is set to false, the shapefile is repacked.
Sandro
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170706/055f6b20/attachment-0001.html>
More information about the QGIS-Developer mailing list
