[QGIS-Developer] Confused by QGIS 3 Labeling
Martin Dobias
wonder.sk at gmail.com
Thu Jul 6 08:55:15 PDT 2017
Hi Calvin
On Thu, Jul 6, 2017 at 5:06 PM, C Hamilton <adenaculture at gmail.com> wrote:
> Formally I was using the following in my code to add a default label to my
> points vector layer:
> label = QgsPalLayerSettings()
> label.readFromLayer(ptLayer)
> label.enabled = True
> label.fieldName = 'label'
> label.placement= QgsPalLayerSettings.AroundPoint
> label.writeToLayer(ptLayer)
> In looking at the api break documentation readFromLayer and writeToLayer
> have been removed and I need to somehow use QgsAbstractVectorLayerLabeling,
> but I cannot see what I need to change just to add a label to my point
> layer. I am not trying to do anything fancy. All I want is to specify a
> field to be used to label the points layer and just use the default styling.
> Any help understanding the new API changes would be appreciated.
This should work:
settings = QgsPalLayerSettings()
settings.fieldName = 'id'
labeling = QgsVectorLayerSimpleLabeling(settings)
layer.setLabeling(labeling)
Please note that it is still too early to port your code to QGIS 3.0 -
there may be further API breaks. Here I would say that
QgsPalLayerSettings class may be renamed and its API may be updated.
Regards
Martin
