[QGIS-Developer] QGIS/OGR: FeatureIds reassigned on write to data provider?
Sandro Mani manisandro at gmail.com
Tue Jul 11 05:39:22 PDT 2017
On 11.07.2017 14:31, Even Rouault wrote:
> On mardi 11 juillet 2017 14:00:28 CEST Sandro Mani wrote:
> > On 10.07.2017 13:58, Even Rouault wrote:
> > > > I did some playing around and came up with some FeatureId
> mapping code
> > > > which is pretty space efficient (basically requiring just
> > > > 3*nDeletedFeatures entries), see below.
> > > > The code however assumes that the gaps in the fid-sequence are
> filled by
> > > > decreasing the fids after the gap, which may be pretty specific
> to the
> > > > OGR/Shapefile behaviour.
> > > This should clearly be restricted to Shapefiles. Other drivers don't
> > > have this compaction logic and will let happily holes in the
> feature ids.
> > > > Hence in my view such code should really belong
> > > > into the OGR provider (or perhaps even ogr itself) and not in the
> > > > plugin. Thoughts?
> > > Regarding putting that in OGR itself, there's no such API for that
> > > right now, and I'm not completely clear of the value to add one
> > > (specific use case, for a single driver)
> > > Perhaps the QGIS OGR provider would be a better place for now.
> > So that kinda works, but repacking still causes dreadful performance
> > (say after fixing a couple of hundred "minimal area" errors, which
> > results in the small features getting deleted, the shapefile is repacked
> > after every delete).
> > So I'd really need a way to freeze repacking, even just for the timespan
> > the plugin is busy fixing the errors. Unless there are some better
> > ideas, I'll look at adding corresponding methods. A cool name would be
> > beginTransaction/endTransaction which is kinda generic and could make
> > sense for other providers as well, but unfortunately it collides with
> > the existing transaction logic (QgsTransaction) which is about
> > multi-layer transaction groups...
> As you venture into the OGR provider, you'll see related things :
> - there's an internal to the OGR provider startTransaction() /
> commitTransaction() that is used only for SQL based drivers, and in
> the scope of a single operation like addFeatures() / deleteFeatures() /..
> - there's a enterUpdateMode() / leaveUpdateMode() pair respectively
> called by QgsVectorLayer::startEditing() /
> QgsVectorLayer::commitChanges(). The purpose of that is to
> respectively re-open a read-only file as read-write, and re-open it
> from read-write back to read-only. This is for scenarios involving
> QGIS with other GIS open at the same time on th same file: if QGIS
> opens it in read-write mode, that prevents the other software from
> opening it (was initially for MapInfo).
> We could potentially imagine to defer the repacking at
> leaveUpdateMode() time, actually in the close() method which is called
> when the reference counter of the update mode drops to zero (*),
> instead of doing it at the end of each operation.
Thanks for the insight, I'll look at that approach.
Sandro
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170711/0deaa5d6/attachment.html>
More information about the QGIS-Developer mailing list
