[QGIS-Developer] Editable CSV files
Andreas Neumann a.neumann at carto.net
Wed Jul 19 07:35:28 PDT 2017
Hi all,
Thanks all for your feedback. The "Add delimited text" way of loading
CSV data is a lot more powerful and more flexible than the OGR way. So I
would really prefer to use the CSV this way and still be able to edit
and save directly to the CSV.
Would this be possible as an enhancement?
I don't need concurrent/simultaneous editing with Spreadsheets. All I
want is an editable CSV directly from QGIS, so that it could be at a
later time, be opened in Spreadsheets again (not opened at the same time
in QGIS as well).
Andreas
On 19.07.2017 16:23, Stefan Keller wrote:
> Nice hints, Bernhard and Nyall
> Thinking about, there's no really complicated technical reason why
> concurrent editing would not work.
> It's simply a matter in which mode the reader SW opens the file.
> * QGIS delimited text provider: locks.
> * QGIS OGR data provider: does not lock - but not ask to reload if
> file has changed.
> * LibreOffice Writer and Excel: lock
> * Notepad++: does not lock - and asks to reload if file has changed
> * Other text editors: depends...
> So, in fact e could slightly enhance the situation, if QGIS delimited
> text provider would not lock (and eventually ask to reload when file
> changed).
> The remaining problem is that we can't change the behaviour of
> LibreOffice Writer (Windows) nor Excel short term...
> Eventually someone could ask the LibreOffice Writer dev's for a solution?
> :Stefan
> 2017-07-19 8:48 GMT+02:00 Nyall Dawson <nyall.dawson at gmail.com>:
>> On 19 July 2017 at 15:45, Andreas Neumann <a.neumann at carto.net> wrote:
>>> Hi,
>>> Is there a particular technical reason why csv/text files aren't editable in
>>> QGIS? Or is this mainly for historical reasons and it could be implemented
>>> as editable with reasonable effort?
>> It depends how they are loaded. If you load them using the delimited
>> text provider, then no, they aren't editable.
>> BUT.....
>> if you load them as a ogr layer, they will be! (Since GDAL supports this)
>> So drag and drop them to QGIS, or add via the "add vector layer"
>> button and they'll be editable.
>> Nyall
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
