[QGIS-Developer] Editable CSV files
Borys Jurgiel
lists at borysjurgiel.pl
Wed Jul 19 08:01:42 PDT 2017
Dnia środa, 19 lipca 2017 09:32:54 Paolo Cavallini pisze:
> unfortunately, AFAIK drag&drop does not alow to spatialize the text
> layer, so in most cases an user is forced to use the delimited text
> provider. There are external plugins that allow spatialization after
> loading.
> All the best.
You can spatialize them by drag&drop. In GDAL >= 2.1 it's as easy as creating
an additional .csvt file with column type declarations. In older versions of
GDAL, you need to access the csv via an additional .vrt file. See [1].
Hovever, there are still unsolved problems. With GDAL 1.10, I only can add new
features (like it is in postgis layer with missing primary key). With GDAL
2.2, I have full edit capabilities, however, QGIS corrupts the .csvt file on
save by replacing the CoordX/CoordY/Point(X)/Point(Y) declarations with simple
Float. As a result, next time you try to open the file, QGIS finds it non-
geometry.
I guess fixing the last issue is a way to go. Once it's solved, maybe we even
don't need the CSV provider anymore?
Regards,
Borys
[1] http://www.gdal.org/drv_csv.html
