[QGIS-Developer] Editable CSV files
Paolo Cavallini cavallini at faunalia.it
Wed Jul 19 21:54:02 PDT 2017
Il 20 luglio 2017 00:09:56 CEST, Nyall Dawson <nyall.dawson at gmail.com> ha scritto:
>On 20 July 2017 at 00:35, Andreas Neumann <a.neumann at carto.net> wrote:
>> Hi all,
>> Thanks all for your feedback. The "Add delimited text" way of loading
>CSV
>> data is a lot more powerful and more flexible than the OGR way. So I
>would
>> really prefer to use the CSV this way and still be able to edit and
>save
>> directly to the CSV.
>> Would this be possible as an enhancement?
>I still think the "proper"/"most open source ecosystem friendly"
>approach here would be to port the extra features which QGIS'
>delimited text provider has across to GDAL's csv driver. Then the "add
>delimited text" button would become just a frontend for setting up the
>parameters for GDAL's driver (and possibly auto-creation of a csvt
>file too).
>Given that gdal already supports editable csv (and is used by many
>projects outside of QGIS), it seems more friendly to the wider
>community if any investment was about enhancing gdal's driver instead
>of adding write support within QGIS only.
>That's just my 2c!
>Nyall
>> I don't need concurrent/simultaneous editing with Spreadsheets. All I
>want
>> is an editable CSV directly from QGIS, so that it could be at a later
>time,
>> be opened in Spreadsheets again (not opened at the same time in QGIS
>as
>> well).
>> Andreas
>> On 19.07.2017 16:23, Stefan Keller wrote:
>>> Nice hints, Bernhard and Nyall
>>> Thinking about, there's no really complicated technical reason why
>>> concurrent editing would not work.
>>> It's simply a matter in which mode the reader SW opens the file.
>>> * QGIS delimited text provider: locks.
>>> * QGIS OGR data provider: does not lock - but not ask to reload if
>>> file has changed.
>>> * LibreOffice Writer and Excel: lock
>>> * Notepad++: does not lock - and asks to reload if file has changed
>>> * Other text editors: depends...
>>> So, in fact e could slightly enhance the situation, if QGIS
>delimited
>>> text provider would not lock (and eventually ask to reload when file
>>> changed).
>>> The remaining problem is that we can't change the behaviour of
>>> LibreOffice Writer (Windows) nor Excel short term...
>>> Eventually someone could ask the LibreOffice Writer dev's for a
>solution?
>>> :Stefan
>>> 2017-07-19 8:48 GMT+02:00 Nyall Dawson <nyall.dawson at gmail.com>:
>>>> On 19 July 2017 at 15:45, Andreas Neumann <a.neumann at carto.net>
>wrote:
>>>>> Hi,
>>>>> Is there a particular technical reason why csv/text files aren't
>>>>> editable in
>>>>> QGIS? Or is this mainly for historical reasons and it could be
>>>>> implemented
>>>>> as editable with reasonable effort?
>>>> It depends how they are loaded. If you load them using the
>delimited
>>>> text provider, then no, they aren't editable.
>>>> BUT.....
>>>> if you load them as a ogr layer, they will be! (Since GDAL supports
>this)
>>>> So drag and drop them to QGIS, or add via the "add vector layer"
>>>> button and they'll be editable.
>>>> Nyall
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe:
>Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Sure, agreed fully.
All the best.
Sent from mobile. Sorry for being short
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170720/2c52f6a0/attachment.html>
More information about the QGIS-Developer mailing list
