[QGIS-Developer] [PSA] Travis CI is up and running again
Alessandro Pasotti apasotti at gmail.com
Thu Jul 20 01:44:06 PDT 2017
On Thu, Jul 20, 2017 at 9:29 AM, Matthias Kuhn <matthias at opengis.ch> wrote:
> On 7/20/17 8:56 AM, Alessandro Pasotti wrote:
> That's very interesting, Alessandro
>> How are dependencies built, using some packaging system or a set of
>> scripts? Are the scripts or recipes around somewhere?
> Oh, sorry for not being clear, we are not building dependencies but only
> QGIS itself, but I think that the general workflow could be used for
> building the dependencies in the docker instead of QGIS and push the image
> to docker HUB.
> So, when Travis starts, it will pull the pre-built docker image with all
> dependencies already built and either install them in Travis and build QGIS
> or build QGIS inside the docker "inside" Travis.
> BTW, the recipes are here: https://github.com/boundlessgeo/qgis-testing-
> environment-docker
> Thanks for the pointer.
> So you are mostly using the dependencies directly from Ubuntu 16.04 except
> for one dependency that you build?
Yes, the purpose of that docker is provide a testing environment for
plugins, in that context, QGIS is "the" dependency that is being built.
>> We were wondering if this could be done directly on travis before the
>> build starts (skipping any package that is already up to date in the cache).
>> The nice benefit of this compared to a separate build as you are doing on
>> AWS would be that if something needs a new dependency (thinking of qca,
>> qtkeychain, ...) it can directly integrated in the same pull request.
>> What do you think about this approach?
>> Thanks
>> Matthias
> I'm not sure I get it right, do you mean that you want to build the
> dependencies on Travis within the same job that builds QGIS?
> Correct
> I think that this would add a considerable time, that's why we are
> building on AWS and pull the pre-built docker, but I guess that the goal is
> completely different.
> Normally they should be cached and not rebuilt.
Oh, I see, I would not know how to do that though.
> I was thinking that the dependencies do not vary frequently, hence we
> should be able to build the dependencies docker nightly and when the main
> QGIS Travis job starts we can pull the docker with the dependencies
> substantially lowering the time needed to run the entire job.
> I imagine version updates happen more often. For example a new gdal
> version that brings in some geopackage functionality which is covered by a
> unit test.
More often than daily? I was thinking at building the dependencies in the
docker daily with AWS. We could even have different set of dependencies in
different docker tags and use a Travis matrix to test them all ... given
that it does not add too much to the Travis allowed time.
> What's the workflow here?
> If this can be added directly inside a pull request this has some
> advantages like
> a) responsibility (even without commit rights on the qgis repo you can
> build the deps in the pull request)
> b) sandboxing (if the library is updated in a centralized repository and
> the new gdal version kills some other unit tests we will have that also
> failing on master).
That's a big advantage, I agree.
The bottomline is that if you know how to do that and it will work without
timing out, your solutions is for sure the best one.
Cheers
Alessandro Pasotti
w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170720/e3443770/attachment-0001.html>
More information about the QGIS-Developer mailing list
