[QGIS-Developer] Regular vs spatialite sqlite database
Richard Duivenvoorde
rdmailings at duif.net
Mon Jul 24 04:31:10 PDT 2017
On 24-07-17 12:50, a.furieri at lqt.it wrote:
> On Mon, 24 Jul 2017 11:32:17 +0200, enrico chiaradia wrote:
>> My second implementation uses Spatialite DB but I found it
>> surprisingly slower than shapefile ...
>> In my last implementation, I used a mixed approach, creating both
>> shapefiles to store geometries and regular sqlite db to store simple
>> tables. That is fast and space saving but it generates too much files.
> Hi Enrico,
> SpatiaLite simply is an extension to SQLite, so both them will
> have exactly the same identical speed when handling regular
> (non Spatial) Tables.
Hi Enrico,
Just for completeness, did you consider using GeoPackage (also sqlite
based)?
See this older blog post for some differences between Spatialite and
GeoPackage: [0] The author is one of the Geopackage guys, maybe Sandro
(or others) wants to add arguments against it.
The reason I promote GeoPackage nowadays, is that I think open standards
are the way to go...
Regards,
[0] https://cholmes.wordpress.com/2013/08/20/spatialite-and-geopackage/
