[QGIS-Developer] QGIS-Server 2.99: Apache Internal Server Error
Benedikt Bonath
b.bonath at googlemail.com
Tue Jul 25 08:45:54 PDT 2017
Ok, thanks a lot for that fast answer. Maybe this question should have been
formulated different. Thats for sure not an issue of QGIS - I was just
wondering how I can save the GetMap-response in a valid *.png by requesting
the *.fcgi directly. But just in case the solution is in someone mind
already, it would be great to know. Otherwise I will figure that out
someday later.
Regards
Benedikt
2017-07-25 17:18 GMT+02:00 Alessandro Pasotti <apasotti at gmail.com>:
> On Tue, Jul 25, 2017 at 5:01 PM, Benedikt Bonath <b.bonath at googlemail.com>
> wrote:
>> Hi everybody,
>> I have some problems to run QGIS-Server 2.99.
>> I'm not sure where the problems exactly come from: mod_fcgid, QGIS-Server
>> or my own settings?
>> With the LTR-Version of QGIS-Server everything works just fine, so I
>> guess the issues are in my environment variables or the current QGIS-Server
>> itself.
>> Hopefully someone is able to answer this question.
>> The Systems I tried with are (both were clean before):
>> 1.
>> Debian stretch
>> Own QGIS-master build AND nightly apt-packages
>> Apache (v2.4.25) with mod_fcgid (v2.3.9)
>> 2.
>> Windows 7
>> Latest OSGeo4W QGIS-Dev Version
>> Apache 2.4.18 with mod_fcgid (v2.3.7)
>> ----DEBIAN----
>> When I run the qgis_mapserv.fcgi directly in the command line, everything
>> is fine and I get the right response back.
>> ##Direct Request
>> QUERY_STRING="SERVICE=WMS&VERSION=1.3.0&MAP=/usr/lib/cgi-bin
>> /test.qgs&REQUEST=GetProjectSettings" QGIS_SERVER_LOG_LEVEL="1"
>> QGIS_SERVER_LOG_FILE="/tmp/qgis_server.log"
>> /usr/lib/cgi-bin/qgis_mapserv.fcgi
>> (Btw: Another Problem is to store the response of a GetMap-Request in
>> *.png-File 'QUERY_STRING="......REQUEST=GetMap" ./qgis_mapserv.fcgi >
>> /tmp/test.png' because the first four lines are ASCII-Informations about
>> QGIS Server. Maybe someone knows a solutions for that as well?)
> I can't tell about the others, but this one is not an issue, it is how
> HTTP works, the first lines are part of the HTTP header, the end of the
> header is an empty line, the body follows.
> Regards
> Alessandro Pasotti
> w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170725/e8c51fc8/attachment.html>
