[QGIS-Developer] Pull request that keeps on failing on timeouts on supposedly fast tasks
Andrea Aime andrea.aime at geo-solutions.it
Tue Jul 25 10:33:06 PDT 2017
I have a pull request out that is failing on source code formatting and sip
checks,
after a delay of 60 seconds. Here is an excerpt:
4/6 Test #2: qgis_spelling ....................***Timeout  60.02 sec
Spell check
TRAVIS PR BRANCH: textsymbolizer_sc
Running spell check on files: python/core/qgsvectorlayerlabeling.sip
python/core/symbology-ng/qgssymbollayerutils.sip
src/core/qgsvectorlayer.cpp src/core/qgsvectorlayerlabeling.cpp
src/core/qgsvectorlayerlabeling.h
src/core/symbology-ng/qgssymbollayerutils.cpp
src/core/symbology-ng/qgssymbollayerutils.h
tests/src/python/test_qgssymbollayer_createsld.py
tests/testdata/symbol_layer/lineLabel.qml
tests/testdata/symbol_layer/polygonLabel.qml
tests/testdata/symbol_layer/simpleLabel.qml
Progress: 0/6
Progress: 1/6
Progress: 2/6
Progress: 3/6
Progress: 4/6
    Start 6: PyQgsDocCoverage
5/6 Test #5: qgis_sip_uptodate ................***Timeout  60.02 sec
Full job logs:
https://travis-ci.org/qgis/QGIS/jobs/257345808
Pull request itself:
https://github.com/qgis/QGIS/pull/4838
I have updated the pull request to master and re-pushed like 3 times
already, and it keeps
on failing the same way.
Is there anyone with a clue as to what might be happening here? I don't see
anything special in the logs.
Regards,
Andrea Aime
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39  339 8844549
http://www.geo-solutions.it
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170725/1a545410/attachment-0001.html>
More information about the QGIS-Developer mailing list
