[QGIS-Developer] Exporting large GeoTIFF files from print composer
Neumann, Andreas
a.neumann at carto.net
Wed Jul 26 08:33:37 PDT 2017
Hi Matthias,
Here is more info:
First, I receive a warning saying: "To create image 28346x22440 requires
about 1908 MB of memory. Proceed?" with an OK / Cancel button.
Then I press "OK"
A dialog appears where I can choose where to store the raster file.
Then a dialog titled "Image export options" appears, where I could do
various settings, like - again selecting the dpi, width and height and I
could "Crop to content".
I leave all settings as they are by default and press "Save".
Then the final and blocking error message dialog is:
"Trying to create image #1 (28346x22440 @ 300dpi) may result in a memory
overflow. Please try a lower resolution or a smaller papersize".
Then I can only press "OK" and the image isn't exported.
Thanks for having a look at this,
Andreas
On 2017-07-26 14:48, Matthias Kuhn wrote:
> Hi Andreas,
> can you send us the warning literally (German or English)?
> I remember an issue report (or gis.se question) about an artificial limit that was formulated like a warning but was indeed preventing from doing an export. Sounds pretty much like what you are experiencing.
> Matthias
> On 7/26/17 9:35 AM, Neumann, Andreas wrote:
>> Hi,
>> I would like to export a large format QGIS print composer to a GeoTIFF file.
>> Page format is 2.4 x 1.9 m and I would like to export at 300 dpi. It is for sending to a copy shop to print out for a trade fair in our province.
>> I can successfully export at 270 dpi, but if I go beyond, QGIS tells me that I may experience a "memory overflow".
>> My machine is 64bit (Win 7) and has 16GB of memory.
>> Is this an arbitrary artificial threshold value where QGIS refuses to export? Would it potentially work, if the barrier wouldn't exist? Could I somehow bypass this barrier?
>> Thanks if you have any idea.
>> Andreas
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170726/7501f004/attachment.html>
