[QGIS-Developer] SIP coverage test removal and Travis optimization
Rouzaud Denis denis.rouzaud at gmail.com
Fri Jun 2 04:45:35 PDT 2017
Hi
> On 2 Jun 2017, at 11:48, Matthias Kuhn 🌍 <matthias at opengis.ch> wrote:
> Hi Denis
> On 06/02/2017 11:17 AM, Denis Rouzaud wrote:
>> Hi Nyall,
>> Thanks for the feedback.
>> Le mer. 31 mai 2017 à 23:14, Nyall Dawson <nyall.dawson at gmail.com <mailto:nyall.dawson at gmail.com>
>> <mailto:nyall.dawson at gmail.com <mailto:nyall.dawson at gmail.com>>> a écrit :
>>    On 31 May 2017 at 22:15, Denis Rouzaud <denis.rouzaud at gmail.com <mailto:denis.rouzaud at gmail.com>
>>    <mailto:denis.rouzaud at gmail.com <mailto:denis.rouzaud at gmail.com>>> wrote:
>>> Dear all,
>>> Our automatic SIP files generation is almost there and I would like to
>>> remove the SIP coverage test from running on Travis.
>>> Is this acceptable?
>>    In general, but...
>>> Is there any reason to keep the test (running on Travis)?
>>    There's 2 extra things the sip coverage test does which the sipify
>>    test doesn't:
>>    1. Flags if a class is totally missing from the bindings. The sipify
>>    test can't detect when someone's added a new header to the project
>>    without adding a corresponding .sip include to the
>>    core/gui/server/analysis.sip files. Ideally this would be fixed with
>>    some cmake magic which avoids the need to even manually build the
>>    core.sip/gui.sip/etc files...
>> So, we have 3 types of headers in core:
>> 1) automatic SIP file creation
>> 2) manual SIP file creation (might be not needed anymore at some point)
>> 3) no SIP file creation
> How do you intend to handle additional files like `conversion.sip`?
> Something like this?
> core.sip.template:
> %Include conversion.sip
> [auto_generated_files] // Some kind of placeholder
Or something like
%Include auto_generated_files.sip
with a file with all of them.
Anyway, something like this, yes.
Would you prefer the CMake or the script approach?
I find it weird that CMake would output files which would be written in the source, so I would vote for the script.
> Matthias
>> What I would propose is to use some macro definition in the header for
>> case 2) and 3), like:
>> #define SIP_MANUALLY_CREATED
>> or
>> #define SIP_NOT_GENERATED
>> By default, the SIP file would be automatically created.
>> The core/gui/etc.sip could then automatically be generated either by
>> CMake or by a script.
>> This would depend if we want to keep the SIP files in the source. I tend
>> to think they're quite useful there for inspection and that the sipify
>> script is (still?) too fragile to fully trust it.
>> If we keep them in source, does it make sense to use CMake to build the
>> core.sip file? or a script run by prepare-commit.sh as it is now?
>> What do you think?
>>    2. Checks that the methods *are* actually accessible in the Python
>>    bindings. Occasionally there'll be weird things where even though a
>>    method is correctly listed in the .sip files, it just doesn't exist in
>>    the Python library. There's no pattern here - it happens differently
>>    on different platforms. But this is a sip bug, so I don't really care
>>    if we lose this extra check.
>>    For me 1 would need to be addressed before we can drop the test.
>>    Nyall
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170602/52d32eee/attachment-0001.html>
More information about the QGIS-Developer mailing list
