[QGIS-Developer] Processing R scripts - TypeError: cannot concatenate 'str' and 'NoneType' objects
René-Luc Dhont
rldhont at gmail.com
Tue Jun 6 05:36:39 PDT 2017
Hi Dev,
I have fixed https://issues.qgis.org/issues/16618 in 2.18 and 2.14.
Regards,
René-Luc
Le 05/06/2017 à 12:09, Giovanni Manghi a écrit :
> Hi,
> I confirm that in previous QGIS releases (2.14/2.16 for example) R
> scripts were working as expected.
> So I added
> to the list of regressions that must be fixed in time for the next LTR
> https://docs.google.com/spreadsheets/d/1frZQU8bwGX499WMvtOc6GDIWqEuSv3QHz3zc90TS46Q/edit?usp=sharing
> cheers!
> -- G --
>> Maybe a fix ...
>> On Fri, Jun 2, 2017 at 8:31 PM, Anita Graser <anitagraser at gmx.at> wrote:
>>> File "C:/OSGEO4~1/apps/qgis-ltr/./python/plugins\processing\algs\r\RAlgorithm.py",
>>> line 404, in getExportCommands
>>> commands.append('cat("##' + out.name + '",file="' + outputDataFile +
>>> '",sep="\n",append=TRUE)')
>> Not sure if it breaks anything else, but if I add
>> elif isinstance(out, OutputHTML):
>> pass
>> before the offending
>> elif out.name != RAlgorithm.R_OUTPUT_VALUES:
>> outputDataFile + '",sep="\n",append=TRUE)')
>> commands.append('cat(' + out.name + ',file="' +
>> Then the HTML output is created and visible in the results viewer and there
>> is no error.
>> I'm not sure what the problematic lines were supposed to do anyway ...
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
