[QGIS-Developer] Lizmap - "Story map" feature POC with QGIS user map data
kimaidou
kimaidou at gmail.com
Tue Jun 6 08:16:39 PDT 2017
Hi all,
I am working on a new feature for upcoming version of Lizmap Web Client,
which allows the user
* to move from one layer object to the next , and shows:
* to see the feature information ( based on Lizmap popup)
* to see the geometry of the feature (highlighted in yellow) , optionnaly
The editor of the QGIS project will choose :
* a coverage layer (same principle as the atlas)
* a label field used to fill a combo box from the layer features
* a field used to order the layer features (usually the label field)
* buttons to move backward/forward, which means to the previous or next
feature
* a button to start an animation, with an option to set the step duration
(5 s by default)
Changing the user in the combo box will trigger the move to the
corresponding feature
I have used QGIS user map data to build a demo
https://plugins.qgis.org/community-map/
Please tell me if I have the permission to use this data. Obviously, if
using this data is not possible, I will shut down the demo !
The link is
http://dev.lizmap.3liz.com/index.php/projects/demonstration/qgis_community
Since this feature is based on a layer, you can imagine other scenarios of
use.
Cheers
Michaƫl
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170606/56d56eda/attachment-0001.html>
