[QGIS-Developer] QGIS 3 > Processing: some test
Paolo Cavallini
cavallini at faunalia.it
Fri Jun 9 09:46:09 PDT 2017
Hi all,
I did some testing of new Processing commands, on a freshly compiled QGIS.
* Aspect throws an error:
{'INPUT_LAYER': <qgis._core.QgsRasterLayer object at 0x7fd70c597558>,
'OUTPUT_LAYER': <qgis._core.QgsProcessingOutputLayerDefinition object at
0x7fd70c597678>, 'Z_FACTOR': 1.0}
File
"/usr/local/src/qgis/QGIS/build_qgis3/output/python/plugins/processing/gui/Postprocessing.py",
line 70, in handleAlgorithmResults
dataobjects.load(l, name, alg.crs,
AttributeError: 'Aspect' object has no attribute 'crs'
the same raster works fine with 2.x
* barplot does not return a result (result viewer is empty)
{'INPUT': <qgis._core.QgsProcessingFeatureSourceDefinition object at
0x7fd71ef1c1f8>, 'OUTPUT':
0x7fd71ef1c288>, 'VALUE_FIELD': 'POP1961', 'NAME_FIELD': 'PROVINCIA'}
* both frequency analysis and Number of unique values in classes return:
This algorithm cannot be run :-(
This script has a syntax errors. Problem with line: ##Fields=Field Input
* keep n biggest parts:
This script has a syntax errors. Problem with line: ##To_keep=number 1
* basic statistics for fields:
File
"/usr/local/src/qgis/QGIS/build_qgis3/output/python/plugins/processing/algs/qgis/BasicStatistics.py",
line 152, in processAlgorithm
self.createHTML(output_file, data)
File
line 265, in createHTML
with codecs.open(outputFile, 'w', encoding='utf-8') as f:
File "/usr/lib/python3.5/codecs.py", line 895, in open
file = builtins.open(filename, mode, buffering)
FileNotFoundError: [Errno 2] File o directory non esistente: ''
* buffer:
* rasters appear in the list of layers, but no result nor error is
given when chosen
* for vector polygons, a new layer is created, but geometries are
unchanged (no buffer)
* there are two QGIS entries (I imagine one Py and one C++), confusing
for the user
* clip, check validity, polygon extent, boundary, bounding boxes,
centroids, add field, add autoincremental field, delete field seem to be
all working fine.
I know it's very early, please let me know if I better stop testing.
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
