[QGIS-Developer] Postgis loading using COPY instead of INSERTS?
Matthias Kuhn matthias at opengis.ch
Sat Jun 10 05:17:21 PDT 2017
On 6/10/17 2:11 PM, Nyall Dawson wrote:
> On 19 May 2017 at 17:04, Régis Haubourg <regis.haubourg at gmail.com> wrote:
>> Forwarding Nyall tips, might be usefull for others
>>> I tested drag and drop in browser and dbmanager (in 2.18.7 and master) and
>>> couldn't find anything about that in the issues or the code base.
>> Both of these codepaths use QgsVectorLayerExporter, which batches
>> calls to QgsVectorDataProvider::addFeatures in groups of 200 features.
>> So there's definitely the potential for a good speed bump here by
>> moving to the COPY command.
>>> Did I miss something? Is there someone working in that area?
>> I don't think so. The tricky bit would be handling the "RETURNING"
>> part of the INSERT command, which is used to update the add features
>> with their new feature IDs/primary keys. I'm not sure that's possible
>> using a COPY command.
> I've been thinking here...
> I think it may be worthwhile to add a "flags" argument to the vector
> data provider addFeature(s) methods (i.e. add it to the base class
> methods in QgsFeatureSink). Initially we could have a single available
> flag - something like "SkipFidUpdates". If set, providers could then
> choose to optimise the way they add features to the backend store
> given that the updated feature ids aren't required. We could then
> safely use COPY in the postgres provider when this flag is set.
> I'd estimate 90+% of the time we are bulk adding features we don't
> care about the updated feature ids, and it's only when adding small
> amounts of features that this updated id is used. Definitely for
> things like QgsVectorLayerExporter it's not required, so we'd get the
> COPY speed boost used.
> Thoughts?
This would also help fixing https://issues.qgis.org/issues/16552
Sounds like a good idea to me
Matthias
> Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
