[QGIS-Developer] Service area error in master Processing
Anita Graser
anitagraser at gmx.at
Sat Jun 10 07:37:06 PDT 2017
Thank you for the quick response Matthias!
This is the log output
2017-06-10T16:36:02 2 Uncaught error while executing algorithm
File
"C:/OSGEO4~1/apps/qgis-dev/./python/plugins\processing\core\GeoAlgorithm.py",
line 198, in execute
self.processAlgorithm(context, feedback)
File
"C:/OSGEO4~1/apps/qgis-dev/./python/plugins\processing\algs\qgis\ServiceAreaFromLayer.py",
line 258, in processAlgorithm
geomUpper = QgsGeometry.fromMultiPoint(upperBoundary)
TypeError: index 33 has type 'str' but 'QgsPointXY' is expected
2017-06-10T16:36:02 2 <class
'processing.core.GeoAlgorithmExecutionException.GeoAlgorithmExecutionException'>
As far as I can tell, this algorithm did not exist in 2.18.
Best wishes,
Anita
On Sat, Jun 10, 2017 at 4:09 PM, Matthias Kuhn <matthias at opengis.ch> wrote:
> Hi Anita
> does the log say anything?
> does it work with the same input data in 2.18?
> All the best
> Matthias
> On 6/10/17 3:30 PM, Anita Graser wrote:
> Hi,
> Testing Network analysis tools in Master. Service area (from point) works
> as expected but Service area (from layer) fails with:
> Algorithm Service area (from layer) starting...
> Loading start points...
> Building graph...
> Calculating service areas...
> index 29 has type 'str' but 'QgsPointXY' is expected See log for more
> details
> ... the index number changes depending on the settings.
> Is it just me, or is there a bug?
> Best wishes,
> Anita
> QGIS-Developer mailing listQGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170610/4f741726/attachment-0001.html>
