[QGIS-Developer] multipartToSingleParts via code
Stefano Masera
stefano.masera at arpa.piemonte.it
Tue Jun 13 00:49:27 PDT 2017
Hi Nyali,
in a few words I want to do a multipartToSingleParts (for a VectorLayer) via code without using the processing module.
Thanks!
Stefano
Stefano Masera
Arpa Piemonte
Via Pio VII, 9 - 10135 Torino
www.arpa.piemonte.it
----- Messaggio originale -----
Da: "Nyall Dawson" <nyall.dawson at gmail.com>
A: "Stefano Masera" <stefano.masera at arpa.piemonte.it>
Cc: "qgis-developer" <qgis-developer at lists.osgeo.org>
Inviato: Lunedì, 12 giugno 2017 23:33:07
Oggetto: Re: [QGIS-Developer] multipartToSingleParts via code
On 13 June 2017 at 01:01, Stefano Masera
<stefano.masera at arpa.piemonte.it> wrote:
> Hi list,
> I want to use the 'multiPartToSinglePart' script via code for my plugin.
> I can use it importing processing like this:
> import processing
> processing.runalg("qgis:multiparttosingleparts", input, output)
> but I wan't to use it in a different way, like I already do with the
> 'dissolve' script:
> from qgis.analysis import *
> analyzer = QgsGeometryAnalyzer()
> analyzer.dissolve(input, output)
> (even if I could write:
> import processing
> processing.runalg("qgis:dissolve",input,output)
> Is it possible?
Sorry, I don't understand exactly what it is you're wanting to do. Can
you clarify?
Nyall
Questo messaggio e' stato analizzato ed e' risultato non infetto.
This message was scanned and is believed to be clean.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170613/41ef383d/attachment-0001.html>
