[QGIS-Developer] QGIS 3 > Processing: some test
Paolo Cavallini
cavallini at faunalia.it
Tue Jun 13 07:55:50 PDT 2017
Hi Nyall,
Il 12/06/2017 08:36, Nyall Dawson ha scritto:
>> * barplot does not return a result (result viewer is empty)
> Looks like this happens when you don't pick a destination file. Can
> you re-test and explicitly choose an output file.
tried, still empty wpanel
>> * basic statistics for fields:
>> Traceback (most recent call last):
>> File
>> "/usr/local/src/qgis/QGIS/build_qgis3/output/python/plugins/processing/algs/qgis/BasicStatistics.py",
>> line 152, in processAlgorithm
>> self.createHTML(output_file, data)
>> File
>> line 265, in createHTML
>> with codecs.open(outputFile, 'w', encoding='utf-8') as f:
>> File "/usr/lib/python3.5/codecs.py", line 895, in open
>> file = builtins.open(filename, mode, buffering)
>> FileNotFoundError: [Errno 2] File o directory non esistente: ''
> Should be fixed in master.
no error, but I still do not see a result
>> * buffer:
>> * rasters appear in the list of layers, but no result nor error is
>> given when chosen
fix confirmed, thanks
>> * for vector polygons, a new layer is created, but geometries are
>> unchanged (no buffer)
> Can you retest and let me know what settings lead to this? I can't
> reproduce. By the way dissolve mode in buffer alg should be fixed now.
issue confired:
processing.run("native:buffer",
{'INPUT':QgsProcessingFeatureSourceDefinition('comuni_multi_45c17787_f7f8_43c2_b5b0_1c12acd87ade',
False),'DISTANCE':10,'SEGMENTS':5,'END_CAP_STYLE':0,'JOIN_STYLE':0,'MITRE_LIMIT':2,'DISSOLVE':False,'OUTPUT_LAYER':QgsProcessingOutputLayerDefinition('memory:')})
thanks
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
