[QGIS-Developer] [Qgis-developer] Processing UI looks strange
matteo matteo.ghetta at gmail.com
Wed Jun 14 01:03:41 PDT 2017
HI Etienne,
well I get some installation and reinstallation and messing things up in
my computer so I don't have this problem anymore. Here what I did.
I get some "issues" when designing UI plugins interface with Qt and
using the Qgs Widgets: every time I save the UI in QT Designer, all he
QgsWidget are saved for example as something like qgscollapsible.h and
QGIS is not able to load them.
So I have to manually enter the UI file and replace all the qgsxxxx.h
with qgis.gui
This started to happens when I removed the qgis_customwidgets.py file
from the plugins directory Qt
(/usr/lib/python2.7/dist-packages/PyQt4/uic/widget-plugins/).
Removing this file from there seems to let Processing UI looks fine
while you get this small problem with the qgs widget in QtDesigner
Hope this helps
Cheers
Matteo
More information about the QGIS-Developer mailing list
