[QGIS-Developer] Bug with Statist plugin
    Patrice
    abrabacabra at openmailbox.org
    Wed Jun 14 09:00:52 PDT 2017
There is a bug with the Statist plugin.
The plugin is broken. Python said:
cannot import name NavigationToolbar2QTAgg
As suggested by user'spaceof7'  on github, changing line 49
from matplotlib.backends.backend_qt4agg import NavigationToolbar2QTAgg
as NavigationToolbar
to:
from matplotlib.backends.backend_qt4agg import NavigationToolbar2QT as
NavigationToolbar
fixes the problem.
The git repository doesn't seem up to date (last update is from 2013.)
and code has obviouslychanged since (when comparing sources).
Patrice
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170614/be4a56f5/attachment.html>
