[QGIS-Developer] Use of QtWebKit in plugin
kjoller
niels.k.h at gmail.com
Mon Jun 19 04:48:07 PDT 2017
Hi all
I have been trying to fix a bug in the "Kortforsyningen" plugin for QGIS,
which exists in Ubuntu 17.04 and Debian stretch (and probably other newer
debian based systems), due to QtWebKit not being included in PyQt4
https://github.com/Kortforsyningen/Qgis_plugin_Kortforsyningen/issues/27
The basic trouble is:
ImportError: No module named QtWebKit.QWebView
I have narrowed it down to the the (rather complex) 'About' dialog, where
uic.loadUiType(
os.path.join(os.path.dirname(__file__), 'aboutKortforsyningen.ui')
tries to run a piece of code ending with the line
from QtWebkit.QWebView import QWebView
where on my working (16.04) system, it ends with
from PyQt4 import QtWebKit
I can solve this problem, by putting qtwebkit.py from the PyQt4 source code
into /usr/lib/python2.7/dist-packages/PyQt4/uic/widget-plugins.
My question boils down to:
What is the 'best' way of solving this in other peoples systems? I have
looked at three scenarios:
* Switching to a simpler about dialog in case of QtWebkit-errors (a hacky
try,except)
* Precompiling the UI on a working system before uploading(1)
* Begging to get the widget-plugin file included in the .deb-package on
qgis.org
Thanks,
Niels
(1) When I try to use pyuic4 -o aboutKortforsyningen.py
aboutKortforsyningen.ui -d on my working system, I get
ValueError: API 'QDate' has already been set to version 1
which I can solve buy adding sip.setapi(....) to the start of pyuic4, but is
this can't be the way to do it, can it?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Use-of-QtWebKit-in-plugin-tp5324658.html
Sent from the QGIS - Developer mailing list archive at Nabble.com.
