[QGIS-Developer] Variable syntax: $ vs @
Neumann, Andreas a.neumann at carto.net
Mon Jun 19 05:36:45 PDT 2017
Hi Nathan,
Thank you for the explanation. Makes sense. I will pass this on in the
workshop.
Andreas
On 2017-06-19 14:12, Nathan Woodrow wrote:
> Hey Andreas,
> They are really two different things.  $geometry is really a function that takes no arguments. This has been deprecated in favour calling with () e.g geometry().  @ is only for variables.
> So you can explain it that $ used to be a shorthand way of calling a function that took no arguments which has now been replaced with () at the end to call it. $area = area().  This becomes important because now we support optional arguments meaning you can take 0 to N arguments.
> - Nathan
> On Mon, Jun 19, 2017 at 9:53 PM, Neumann, Andreas <a.neumann at carto.net> wrote:
>> Hi,
>> While preparing for a workshop on expressions I wonder how to explain why some variables are referenced with the $ sign (like $geometry) while other variables start with the @ sign, like @row_number, @layer_name.
>> I know that it has historical reasons and that variables with the @ sign are newer and are implemented using a different technology.
>> But are there plans to get rid of the old $ sign notation and move everything to the @ sign notation?
>> Just wonder how I best explain this to the participants of the workshop.
>> Thanks for your reply,
>> Andreas
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer [1]
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer [1]
Links:
[1] https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170619/9a0b4e46/attachment.html>
More information about the QGIS-Developer mailing list
