[QGIS-Developer] PyQGIS docstrings only show the SIP wrapped function signature, not the actual docstring?
Kevin Stadler
e0425926 at student.tuwien.ac.at
Mon Jun 19 14:31:40 PDT 2017
Hello,
I'm trying to access the docstrings of various QGIS 2.* components
from the IPython console, but instead of the actual documentation I
only seem to get dummy docstrings generated by SIP:
>>> QgsMapLayerRegistry.instance().mapLayers.__doc__
'mapLayers(self) -> object'
>>> QgsMapLayerRegistry.instance().mapLayer.__doc__
'mapLayer(self, QString) -> QgsMapLayer'
>>> QgsVectorLayer.__doc__
'QgsVectorLayer(path: QString = QString.null, baseName: QString =
QString.null, providerLib: QString = QString.null,
loadDefaultStyleFlag: bool = True)'
Using help(...) instead of .__doc__ doesn't look much different. Is
this just something wrong with my build (from the Fedora stable
repository), can somebody reproduce this on a non-Linux build?
I've looked through the mailing list archive but haven't found
anything conclusive. The flag to have SIP generate docstrings
requested here is still enabled:
http://osgeo-org.1560.x6.nabble.com/Sip-flag-to-generate-docstrings-td4485370.html
I'm thinking it might have to do with the new SIP file generation
workflow described here:
http://osgeo-org.1560.x6.nabble.com/automatic-sip-files-generation-td5314970.html
although I'm not clear on which branch this actually applies to (and
whether it might be the source or the solution of my problem)?
Best,
Kevin
