[QGIS-Developer] Print Composer Bug with Scale and Rotation
Mathieu Pellerin
nirvn.asia at gmail.com
Mon Jun 19 21:51:48 PDT 2017
FYI, I coincidentally spotted this nice commit (
https://github.com/nextgis/quickmapservices/commit/9ae9efd6bf2a162762262672bd93c9958cc822d1)
pushed to QuickMapServices' repository. This will make it possible to add
native XYZ layers via the QuickMapServices and therefore benefit from all
of is greatness (rotation as mentioned above, etc.)
On Tue, Jun 20, 2017 at 11:05 AM, Nyall Dawson <nyall.dawson at gmail.com>
wrote:
> On 20 June 2017 at 02:18, C Hamilton <adenaculture at gmail.com> wrote:
> > I am finding real inconsistent behavior with the print composer in QGIS
> > 2.18.9 on Windows 7. The problem manifest quickly if you start with a
> > QuickMapServices base layer such as OSM Standard. In print composer "Add
> new
> > map" and while the map is selected, click on "Item Properties" and try to
> > change the "Scale". It doesn't allow you to manually to change it nor
> does
> > "Map rotation" permit any change.
> > If however when you first start QGIS and then set the current CRS to 3857
> > first and then add the QuickMapServers base layer then you can changed
> the
> > "Scale" however "Map rotation" still does not work correctly.
> > I have also tried WMS services and sometimes it works and sometimes it
> > doesn't.
> > Should I add this to the QGIS issue tracker?
> No - it's a plugin specific bug, so should be filed with the plugin.
> However, I'd strongly suggest using the native XYZ tile provider which
> is present in QGIS 2.18 (see
> https://www.qgis.org/en/site/forusers/visualchangelog218/
> index.html#feature-native-support-of-xyz-tile-layers).
> It has full support for rotation in canvas and composer maps (neither
> QuickMapServices nor OpenLayers plugin support this). It's also much
> more responsive when navigating maps.
> Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170620/3ea903f1/attachment.html>
