[QGIS-Developer] OSGeo4W setup hangs downloading setup.ini.bz2
Radim Blazek
radim.blazek at gmail.com
Fri Jun 23 03:19:27 PDT 2017
It works if "Use IE5 Settings" is checked instead of "Direct Connection".
But there are no particular IE5 settings AFAICT.
Radim
On Fri, Jun 23, 2017 at 11:44 AM, Radim Blazek <radim.blazek at gmail.com> wrote:
> The latest osgeo4w-setup-x86.exe on win7/32bit hangs downloading
> setup.ini.bz2, usually on 98% (32k/33k) but also less, randomly. There
> is no problem to download the file
> http://download.osgeo.org/osgeo4w/x86/setup.ini.bz2 in a browser.
> Similar problem was reported here:
> http://osgeo-org.1560.x6.nabble.com/installation-problem-with-OSGeo4W-Advanced-Installer-under-windows-7-tt5079931.html#a5079942
> "Launch as Administrator" does not help.
> Is there any workaround?
> Radim
