[QGIS-Developer] Get data from QgsFieldExpressionWidget (QGIS Master)
matteo matteo.ghetta at gmail.com
Mon Jun 26 22:52:44 PDT 2017
Hi Nyall,
> In QGIS 3.0 QgsVectorLayer::getValues will do what you want in a single call:
> https://qgis.org/api/classQgsVectorLayer.html#ac8cfb12633ed536da73f42ebff095f99
> That works for either a field:
> layer.getValues('my_field')
> or an expression:
> layer.getValues('my_field * 2')
whoooooa I was not aware of that, thanks!
One further question, I tried it with the example field PH and the
expression PH > 7. This the outputs:
vl.getValues('PH')
([6.81, 6.78, 6.49, 6.72, 6.88, 7.68, 7.69, 7.38, 6.76, 6.84, 6.91,
6.74, 6.77, 6.73, 6.68, 6.94, 6.72], True)
vl.getValues('PH > 7')
([0, 0, 0, 0, 0, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0], True)
with the expression it seems the output is TRUE/FALSE. Any clue to
obtain also the attribute values?
Thanks again
Matteo
More information about the QGIS-Developer mailing list
