[QGIS-Developer] Processing 3.0: Dropping non-QgsZonalStatistics zonal statistics algorithm
    Alexander Bruy
    alexander.bruy at gmail.com
    Tue Jun 27 23:11:18 PDT 2017
alternate alg was introduced in the time, when QgsZonalStatistics offered
only some basic statistical information, e.g. min/max, count and couple of
other values and did not allow to select individual stats.
Now, when QgsZonalStatistics is much more powerful personally I (as author
if this alternate alg) see no sense in keeping other duplicated algorithm.
2017-06-28 9:07 GMT+03:00 Nyall Dawson <nyall.dawson at gmail.com>:
> On 28 June 2017 at 15:55, Mathieu Pellerin <nirvn.asia at gmail.com> wrote:
>> Two statistical outputs (variance and mode) aren't available in QgsZonalStatistics-based alg, while two outputs (minority and majority) are missing from the alternate alg.
> Thanks!
> Mode = majority here, so both algs offer this value.
> Variance is trivial to calculate from the standard deviation, so
> that's not a significant loss.
> I guess the other unknowns are speed & robustness of the two
> algorithms. Is there any open bugs filed against either on hub?
> Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexander Bruy
