[QGIS-Developer] Processing 3.0: Possible change to the Convex Hull algorithm
Anita Graser
anitagraser at gmx.at
Thu Jun 29 01:41:12 PDT 2017
On Thu, Jun 29, 2017 at 10:32 AM, Nyall Dawson <nyall.dawson at gmail.com>
wrote:
> On 29 June 2017 at 18:21, G. Allegri <giohappy at gmail.com> wrote:
> > 1. Allowing multiple field selection for grouping
> > 2. Keeping attributes of first feature when grouping
> > I will accept this criteria, obviously, if it's the preferred solution
> for
> > the mosts.
> > I just want to report that many users (partecipants to courses or
> customers)
> > say they find having the "first feature value" misleading.
> > I agree with them. I would set the field values only for the grouping
> > fields, having the same value within the group, and set null for the
> other
> > fields.
> > The problem raises during a long workflow. At some point you obtain a
> > dataset with unconsisten field values, and it's not always obvious to
> know
> > when and.which field value was set miningless.
> That's fair enough reasoning. Paolo/Anita are you OK with that logic?
Sounds OK to me if it is possible to select multiple grouping fields.
Best wishes,
Anita
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170629/c82db03c/attachment.html>
