[Qgis-developer] Removal of the "Adding GRASS Tools" section in qgis.org?
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Sun Mar 5 14:04:32 PST 2017
Technically the description of how to add GRASS modules to the GRASS plugin seems correct.
However, the whole thing would benefit from some updating as with the plugin upgrade a lot of new stuff was added and e.g. the 3 options max concept did not really work for e.g. the temporal modules.
With GRASS 7.2 more modules might be useful to add. Other modules might need updates (I did not check yet)… So, this info is IMHO relevant to keep, esp. cause this is a nice opportunity for non-developer to contribute…
It is naturally not “used” like e.g. Composer documentation, but one of the important things with documentation is that information is there when you need it…
I guess you would not trash your grandmothers recipe for apple-pie, just because you did not bake one the last two years…
Cheers
Stefan
From: Qgis-developer [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of DelazJ
Sent: søndag 5. mars 2017 22.02
To: Paolo Cavallini <cavallini at faunalia.it>
Cc: qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] Removal of the "Adding GRASS Tools" section in qgis.org?
Thanks to you.
Paolo, Do you think that it should stay there (especially if not used) and/or any idea where we could move it to?
Regards,
Harrissou
Le jeudi 2 mars 2017, Paolo Cavallini <cavallini at faunalia.it<mailto:cavallini at faunalia.it>> a écrit :
> Il 02/03/2017 21:53, Tim Sutton ha scritto:
>>> To avoid keeping wrong/unused/useless texts while moving, I would like
>>> you to let us know if the "Adding GRASS tools" [3] section is worth
>>> keeping. Is it up to date and of use for someone? In which case is it
>>> inline with the other items of the QGIS Dev Guide? Or better moved
>>> somewhere else, e.g. in the GRASS Plugin chapter [4] of User Manual or
>>> ...? Or should we simply trash it?
>> I think Paolo or Radim are best placed to answer this - perhaps email
>> them directly if they don't see this thread. And thanks for cleaning up
>> the docs so nicely!
> AFAIK it should still be valid info, even though I'm not sure someone is
> still working on this.
> All the best.
> Paolo Cavallini - www.faunalia.eu<http://www.faunalia.eu>
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
> https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
> Qgis-developer mailing list
> Qgis-developer at lists.osgeo.org<mailto:Qgis-developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170305/04e0529f/attachment-0001.html>
